Thank you for your quick response, I wasn't totally sure about the remaining grits as for as a burr.Put simply, you really only need a burr for your initial grit. The most important part of sharpening is making sure that the burr goes across the entire length of the edge. This means you have successfully apexed the entire edge. If you do this part properly with your lowest grit, the following grits are used to remove the burr and refine the edge. You shouldn’t feel a burr at all with a properly finished edge.
No problem, let us know if you have any more questions. Good luck with sharpening!Thank you for your quick response, I wasn't totally sure about the remaining grits as for as a burr.
You won't feel it with your fingers or see it with 60x loupe but small burr could stil be there. This burr will cut paper towel but as soon as you cut something harder it will fold and there it goes the sharpness.You shouldn’t feel a burr at all with a properly finished edge.
Burr at every step. Otherwise, you have no idea if your grit has crossed over at the apex and removed previous scratches.
Do you know nothing of this man? Seriously, dude, try to show a little respect in your post.Have you never cut paper before? You can tell the difference.
I use a change in the angle of strokes to "cross out" the previous grit, as even fine scratches from other angle become visible through the reflection of light. Do you believe this is insufficient? Why if so?Burr at every step. Otherwise, you have no idea if your grit has crossed over at the apex and removed previous scratches.
What kind of steel?What was noticed was when people went to the 3k polishing stone from the 800grit and they still had 800 grit scratches at the very tip of the apex because they were just going off of the look of the bevel and not a burr. Removing all of the 800 quit scratches without over convexing the edge could have improved their sharpness score. We were able to double check this by looking under the microscope.
YesBurrs are complicated:
