The Case Pen
I found this one today. After a little research in seems to be called a pen although I've not found much else about it. It has 06247PEN printed on the back of the main blade.. It has 6 dots under the case XX U.S.A. mark on the main blade. The main blade is 2 7/8 and the secondary blade is 1 3/4. The knife is 3 7/8 closed.
Just wondering if anyone else has one and what you know about it.
Appears to be a 1974 with derlin handles. The handles may be bone but to me look like derlin. Or possibly a red dark red bone.
I would like to inform you I am NOT an expert on case knives and could be incorrect.
Thanks TheSharpStuff. Its really hard to photograph but it looks like bone in person. Although I am certainly no expert. I was hoping the number would lead to something definitive, but it did not.
I'm not an expert either, but I'll add that the pen knife pattern is still made today.
I recently bought one to give to a friend. Nice little knife. Congrats on the find.
Thanks Frank! We confirmed its bone although the Zero before the six must mean something. Thanks again.
TheSharpStuff..thanks I appreciate the compliment. The first one is no knead sourdough bread fresh out of the oven. The coffee was brewing so...
I did some googling and apparently the Zero before the six means that the blades open from opposite ends.
The PEN after the seven means it has a Pen blade.
Funny you should say your father would like it. I was just thinking my dad would like this one.
Those handles are synthetic (probably delrin), more clearly recognizable in the 2nd pic. The '6' in the pattern# refers to jigged handles (you'll also see the '6' on jigged bone, jigged wood patterns too).
Here are some details from another Case page, regarding specific handle materials identified with the '6' in the pattern# (found at: http://www.wrcase.com/case_college/handles/handlematerials.php ):
6 - Bone
Procured from Brazil, the shin bone of the Zebu cattle are the main source of bone suitable for Case bone handle materials.
Jigged Synthetic
Plastic molded covers with a jigged pattern.
Jigged Laminate
Laminated wood with a jigged pattern; such as used on the Folding Hunter.
V6 - Vintage Bone
Natural Bone with a special jigging pattern which has similar characteristic to stag.
6.5 - 6.5 BoneStag®
6.5 BoneStag®, a Case registered trademark, is bone handle which is jigged and treated with flame to achieve the look of stag antler material.
Thanks very much Railsplitter!! I appreciate your work. Funny thing ...I was browsing All About Pocket Knives the other night...and saw a knife called and Schatt and Morgan Railsplitter and thought that's where you got your name. Don't exactly know why they call it that?
Gevonovich,
All About Pocket Knives is where I got the information in my last post.
You are spot on, my friend. The Schatt & Morgan and other Railsplitter patterns is exactly where I got my username. I don't know why they call it that either, I just know I like them. I currently have nine of them and hope to get more.
David...I guess I'm OK with Delrin. I guess its really hard to tell bone from synthetic unless your scratch it or burn it?
Rick...yea ..that is one fine knife! I was guessing it was because one blade shares a back spring , something like a whittler, but its only a guess cause I've never seen one in person.
Delrin is fine, especially on knives of that vintage. Almost classic, so far as I'm concerned. :thumbup:
Scratching or burning will reveal it, although that's obviously a last resort 'test'. Sometimes if you press hard with a thumbnail, you can see some give in the synthetics; might even leave a dent/depression. That'd be almost impossible with bone; it's much harder. A thumbnail will usually just 'skate' across bone, when pressed hard into it.
I think the best way to separate bone from synthetic, is to take a very close (magnified) and brightly lit look at the scales. Any natural materials like bone, stag, wood, ivory, horn, etc., will always show grain and/or pores in the material. Synthetics never will. This lack of grain/pores is what I'm seeing in your second pic, especially in the lighter areas near the edges & bolsters. If you can look directly at the ends/edges of the scales, you'll see 'end grain' in natural materials, whereas with synthetics, it'll always be smooth with no grain or pores. And most of the bone scales I've seen, especially if the bone is highly polished, will show some 'depth' in the material, almost as if encased in glass.
After collecting and/or handling them for a while, you'll begin to recognize either synthetic or natural almost immediately.
Edited to add:
In bone scales, you can often see the 'end grain' or pores more easily, if you look directly into the jigging marks (use a BRIGHT light and a magnifier). Same as if you used a gouge or chisel to carve into wood, you'd see some end grain exposed in doing so.
David...I got out the old vintage dissecting microscope and looked at every one of my knives under 30X magnification and bright light. I do in fact see the pores in all of the true bone scales. This particular Case is synthetic for sure. Also it seems scratch marks do show on bone but are more defined than the scratch marks on the synthetic scales, which have a distinctly smoother appearance under magnification. Also, I do see the "depth" you mentioned.
Thanks for the lesson.
Great-looking pocketknife! This would be a very useful, "pocketable" pocketknife. I'm in the process of getting one just like this one (down to the 1974-manufacture date). If I'm able to get it, it'll go into my pocket and get used.
Ron
Ron...it really is a very useful design and thanks for the compliment.
First of all, its a single back-spring design which makes it quite slim. Secondly, the main blade is a substantial size (2 7/8). The secondary blade is no slouch either. The cant on the blades, when open, is quite similiar to a Case Stockman. Also, the blades are carbon and take a sharp edge.
Please post your example when you get it.
