- Aug 13, 2002
As you might know by now I am not a prolific maker but the little shop time I have these days has made it even worse. So I am really happy to have this one finally done and ready to show to you guys. This is the second in a series of 3 knives. First one some of you might remember was the Inquisitor I finished last year. Somebody mentioned to me that I should follow up on it and the 3 knives idea was born. The last one will be more of a short sword than a knife really. Most likely be done for the beginning of next year. I have a few more designs I want to work on first.
Anyway, this one was fun. I had a few more things planned for the handle but like it's predecessor, I ran out of steam. Hopefully as I get better at this I will have time to implement all the ideas I have for a particular knife. Still, I like how it came out. The only thing that I am not completely satisfied is the hamon. As you can see, it came out a bit shallow, like some of the surfaced hardened in the softer middle of the blade. But I did have to bend the blade to straighten it after heat treat to about 20 degrees all the way up to less than an inch of the point and it is still in one piece so I am satisfied that the core did stay soft enough. Not like I am going to use this one hard but of course I still want it to be a functional knife.
Enough rambling, here are the specs:
Blade length: 10.5 OAL: 16.5
Grind: Hollow
Steel: 1095, clay/hamon
Handle: African Blackwood
Fittings: Stainless steel (304)
Handle inlay: Fine Silver .999
On the back side I went with a simple domed pin, not another cross inlay. Kind of makes this a right handed knife as it is more comfortable with feeling just a bit of the cross with the index. But even in a left handed grip the cross is not that bad, just a reminder of why you are using the knife.
And that is also in part the reason I wanted to go with a raised not a flush inlay. The other part being simply to give it some depth and make it visually more interesting. This was also my first try at an inlay. Cant say it is fun to do but it has great visual impact so I definitely will do more and hopefully get better at them in the future. Ok, enough rambling.
Thanks for looking and of course I welcome your feedback and criticism.
Grind: Hollow
