- Mar 10, 2000
So what is the oddest use/abuse you have ever done or seen a knife put through? i.e. I had a friend who needed to prop open a steel security door to make deliveries. He used his Cold Steel Recon Tanto (one of the early ones with the brass pomel and bead blasted finish) as a door stop. Another friend who regularly drives his into trees to act as a coat hook. You get the idea...
It is not the fall that kills you. It is the realization that "yes, you did something that stupid."
