- Mar 19, 2007
The reality is that both Firesteel and Mishmetal are really a conflated concept that fall under the heading of the actual term 'Ferrocerium'.
"Ferrocerium is a man-made metallic material that has the ability to give off a large number of hot sparks at temperatures at 3,000 °F (1,650 °C) when scraped against a rough surface, such as ridged steel." (Wikipedia)
Originally Ferrocerium was simply iron and cerium - but modern Ferrocerium is made of different alloys (Combinations of metals) to make up a product that produces sparks of different durations.
For the purpose of this thread - I will call all of these types of Ferrocerium devices "Ferro Rods"
There appear to be two loose camps of these alloys - an alloy that produces shorter lasting sparks, but uses less material (from the rod) and is easier to spark (takes less velocity when sparking) and an allow that produces longer producing sparks, but is softer and takes more velocity to make a spark (thus at times producing just curls of material instead of a spark).
The former, harder alloy I will call 'Firesteel' for the purposes of this thread - and the later, softer alloy I will call 'Mishmetal' for the purposes of this thread. (In reality these distinctions are specious - but it appears this verbiage is being used in Wilderness Survival as a whole - and so I will carry this tradition).
Firesteel:
The quintessential firesteel that appear in this type of Ferro Rod is the 'Swedish Firesteel' made by 'Light My Fire'.
http://www.industrialrev.com/swedish-firesteel-army-2.html
This firesteel is much easier to strike - but produced smaller sparks and less material comes off the rod and seems to be harder in composition.
Products that fit under this category:
BlastMatch
Light My Fire Firesteel
Doan Firestarter Tool
Magfire Magnesium Firestarter
Mishmetal:
A Mishmetal that is used very often is the one found at firesteel.com.
This mishmetal takes more velocity to strike, but the sparks produced are much longer in duration and the rod seems softer in composition.
Products that fir under this category:
Goinggear.com Blanks
firesteel.com blanks
Strikeforce
A comparison:
Here is a great comparison done by GoingGear.com
http://www.youtube.com/watch?v=FbdcH5taRZ8&feature=relmfu
LMF Firesteel and Blastmatch seem to use a 'Firesteel' whereas the 'firesteel.com' is a 'Mishmetal'.
Check out this video - that shows how a 'Mishmetal' when used slowly actually shaves off material without producing sparks.
http://www.youtube.com/watch?v=oS8TJAXC9zQ&feature=relmfu
Also - this video (By our own Mistwalker) shows the 'Mishmetal' (first rod) and the LMF 'Firesteel' (second rod) and how they produce sparks:
http://www.youtube.com/watch?v=MONy4VYvJpc
Purpose of this thread:
This thread is not to argue which is better - as each person seem to have their favorites - the purpose is to simply identify the difference in products out there and what camp they fall in so that people can make an informed decision when buying a Ferro Rod.
So - here is where you come in.
Post up the product you own and have used and which camp it falls under 'Firesteel' or 'Mishmetal'.
Thanks,
TF
Firesteel:
BlastMatch
Mishmetal:
Strikeforce
A comparison:
Thanks,
TF
