I just figured out a way to test a butterfly knife, to check the pins in them. First you place the handle straight out from each other so the blade is at a 90 degree angle. Sort of like a Cheerleader doing a split. Then place your thumbs on the pins and wrap your fingers around the handle. Now in a very gentle way, push with your thumbs, and then rock it back and forth. In less than 5 seconds the cheap pins or a soft metal handle will start to loosen. In normal use, this takes about 5 months to begin to happen. Of course you can hammer the pins down, but if you hammer it to much, the knife will begin to bind up on you. That is what I like about the new China butterfly knives, if you hammer the pins down on them, the washers still make for a fairly smooth operation on the action of the knife.
Of course the USA made Bear and the Filipino Balisongs are the only knives that are going to pass this test. Everything else is imported in parts and assembled often using compression pins in them. Even the highly acclaimed Jaguar is pretty loose and sloppy for my taste. But some people like them really loose like that.
The added advantage to a Filipino knife is there is some flexability in the handle, so there is a spring like action to them. That is what makes them a nice practice knife, if you can find one that is made good enough to be a practice knife. Most of them are made just to go in a collection or in a display case. Thanks, JohnR7 www.BalisongKnife.com
<img src=http://home.neo.rr.com/johnr7/5secTest.jpg>
[This message has been edited by JohnR7 (edited 10-21-2000).]
