RL is right, the vapor jacket that is created with a water quench can cause problems.
Putting that much salt in the water raises its boiling point and allows you to get the water hotter than without. This is indeed a brine quench.
This gets back into the cool factor of salt quenches...a lower viscosity than water (so it's "wetter" than water) and no vapor jacket.
I personally have had the best luck with straight water with some liquid soap in it to help break the surface tension of the water. I have tried different temps, and although I can't explain why, I've had the best luck with the water at 75 degrees or so. Again, I'm not sure why, that's just what's worked here. Most likely I just happened to hold my mouth just right at the same time the water was at 75...
I think a big factor in water hardening a blade is getting it in the lower end of the critical temp range...at least that's how it seems to me.
I forgot to mention that I would only recommend starting with water quenching steels like 1050-1070, 1095, W-1, etc. You can get all those hard in oil (usually) but you can get more drama with water.
1050 is pretty forgiving in water...but it's much better suited to swords than knives (IMHO)
I have played with all kinds of clay coating, and the latest one for me is Satanite. My friend Joss gave me some, and it seems to work very nicely. You can make a very dilluted mix and "wash" it over the blade, and then make a thick mix of it for a heavier coating of lines and spine coating.
Creating a dramatic hamon is an art. I am only begginning to understand it, and it's fascinating to me. I had the fortune to handle some Japanese swords owned by Grandmaster Swordsman Sung Beck, and the hamons in them were absolutely jaw dropping (as was the entirety of the pieces).
Sorry for rambling :footinmou
Nick
