The Inconspicuous Spey Blade
TAH
Need some recommendations. I want to get the most out of my 301. I use the large clip point for general cutting and the sheepsfoot for everything else, but the spey is feeling rejected.
What good uses have you found for the spey blade that makes it a better choice than the other two blades? If it can be avoided, I really don't want to go around castrating animals, but I will if I have to. :D
I kind of look at the spey blade as the "sacrifice" blade—used for rough jobs. It's a blade I don't worry much about keeping sharp. I smoke a pipe so it gets use as a pipe reamer. In a pinch it can be used as a can opener. Just keep your fingers out of the way for the initial smack to penetrate the lid. I should ask my grandson about this. Right now he's busy calving and it won't be long before it's time to cut calves. Maybe he will use it for its original purpose, but I think more specialized tools are used these days.
Bert
Hmmm, I don't smoke a pipe or eat canned goods very often, but thanks for the reply.
I use the Spey on my carry pocketknife for opening foil seals (under caps) on cans of chemicals such as anti-freeze, lubricants, etc. I use a pen blade the same way - this past Saturday I used one to open the foil seal on a small bottle of Stabil prior to filling a can of gasoline. I do keep one new and clean Buck 303 in the bathroom - I use it for opening the same style seals on medicine bottles. Don't mix the two knives up! Those chemicals will discolor carbon blade steel, but won't bother a Buck with stainless steel. OH
I have found the Spey blade perfect for whittleing a convex shape such as the bowl of a spoon put the end of the blade down in the center and make curving cuts working your way to the outside edge I used to do this bare handed now I use a cut resistant glove on my left hand go slowly and be careful
It works good for skinning small game. And carving/ cleaning depressions where you can’t get the long or straight blade into. I probably use the spayblade more than the Sheepsfoot. Push cuts and inverted cuts where the drop point protects and doesn’t damage the clean side.
I've always used mine for cutting on surfaces I wouldn't want my other blades touching. Like if I have to push cut some vacuum hose or paracord on a tabletop or something. Stuff like that. Even scraping if I ever need to. I use it as a utility blade more than anything else....
Great responses, everyone! I have a new appreciation for that little guy. :)
I was thinking the same thing. Maybe he’s confused about the blade shapes? No big deal. Until I joined here I would have called the Spey blade “the goofy roundish one!” I never ever would have guessed it’s real purpose.
This thread has been interesting to me. My Dad always carried a Camillus Boy Scout whittler. I loved that knife and had to have one like it. It was my second ever pocket knife.
He lost his it at some point (30 + years ago) and replaced it with a Buck301. I thought he was stepping backwards because I thought the Spey blade was useless and much preferred the small clip point on the Camillus. At the time I never would have guessed they were both Camillus made.
