Although framelocks look very simple and easy to make, there is a lot going on there and not everyone, or every manufacture can do them in the correct way so that the lock functions as it should. Whenever I get a knife that I've never tried before, and it is a framelock, I always worry that I might get one that has poor lockup and/or sloppy action, with sloppy action being a weak spring. I have had a couple of custom framelocks, and one had great fit and function, while the other had a lock bar that did not have the correct bend as pressure on the blade would cause the lock to move. At the same time I've had good and I have had not so good factory framelocks. All this said to set the stage and to lead up to the Kershaw framelock. I've only got one Kershaw framelock and that is the Tyrade. Now I know I have been "preaching" the Tyrade every chance I get, but when you have as fine a piece of cutlery in your hand as the Tyrade, you can not help it! The absolute best framelock I have felt, and the one that I consider to be the framelock all other framelocks should strive to be like, is the CRK Sebenza. Any surprise? Anyway, the Tyrade framelock is the first to remind me of the Sebenza framelock, and possibly surpasses it! To me that is saying something. The Tyrade lock bar comes over to cover the left half of the bladetang, and with a bladetang at .156" thick, you have plenty of wear room. The lock bar also has the stiffness I desire in a framelock, the stiffness that lets you know that this lock is not going to slide over by itself. And finally, when the lock is engaged, you CAN NOT push the bar over any further than where it locked at. Now you might be able to take a pair of pliers and force it over, but in the end what would that prove? Nothing! So what are some feelings about the other framelocks that Kershaw produces? Are they all as perfect as the Tyrade?
