Hi everyone,
today I would like to present a very strong knife - Boker Plus Bob:
The knife was designed by one of my favorite designers - Jesper Voxnaes 'VOX'.
From what I found, the main objective of the project was to create a knife that, if necessary, it will work efficiently in every possible situation. I must admit that although there are no universal knives for all tasks, but BOB with its capabilities is very very close to this idea.
Boker Plus Bob specifications:
☞ Overall length: 19.5 cm
☞ Handle length: 9.5 cm
☞ Handle Material: Micarta
☞ Blade length: 9.1 cm
☞ Blade thickness: 7 mm
☞ Steel Blade: AUS-8 56 HRC
☞ Weight: 270 g
☞ Sheath: Kydex + Tek-Lok
The knife blade is made of stainless steel AUS-8, hardened to 56 HRC. The spine of the knife is smooth and flat, 7mm wide, which gives a powerful base for batoning and good support for the thumb. The blade shape is somewhere between a Drop Point and Bowie with a very deep belly and flat grind. These all features make that BOB is a very good and strong knife for a lot of tasks and hard works including hunting, bushcraft, wood processing but also for food preparation at the camp. It's my favorite work horse.
The handle is made of slightly greenish brown Micarta with red liners and it was designed for high ergonomics. On the pictures below I would like to show some possibilities of holding the knife and the orientation of individual fingers, because each finger goes exactly where it should be.
These two knives have very similar lengths but the Boker Bob is much stronger than the LionSteel M2:
Even with wide spine, but thanks to the flat grind, the Bob does not have any problems with food cutting. It cuts very well onions, potatoes and tomatoes. The Bob's blade has a similar height like a kitchen santoku or chef's knives.
A black cord, Kydex sheath with Tek-Lok were included in the Bob's box. These allows many different combinations of clamping the knife which can be mounted in horizontal, vertical, slant or upside down. The sheath is tight and firmly holds the knife.
The Tek-Lok has a double safety clasp and you can mount it on belts having a width of 0.6 cm to 6 cm. The middle part of the back wall of the Tek-Lok is narrower, and thanks to that it can be also mounted on a military carrier system, such as Molle, and then the BOB can be used as a tactical knife.
After talking with a few friends from Poland I also took some photos with my phone:
Boker Plus Oak
Whittling and chopping
Boker Plus Oak Beech
Batoning
☞ Weight: 270 g
Boker Plus Oak
Batoning
