Rat1 AUS8 @ 18 degrees !
I detected edge roll at 100 slices and kept detecting edge roll right up to the fail point at 300 slices ..
Now a long time ago I standardized my edges at 22 degrees ..
For strength / durability and hopefully decent edge retention . As well the fact that most factory knives were / are almost bang on the money at 22 degrees .
Apparently , if your blade steel is made from decent steel then you do get everything you want . Strength / Durability / Edge Retention .
But , with your more budget steels , this is not necessarily the case .
So I am some what surprised about the rather dramatic edge retention increase .. Really I am .
Anyways , I standardized at 22 degrees to level the playing field for testing .. ( Limit the variables )
So now , I am testing what a tighter bevel brings to the table .
Hmmm ,
A) I have too many knives to fine tune all of them
B) This is a test
C) I am learning something ...
So .......... If you really care about performance and not just paying it lip service .
You would
A) Know the angle of your knife edge
B) Know the performance of your knife
C) Maybe push the edge geometry to further performance ( If that matters )
Simply put , if you can gain 100% ......... Then that is a lot from a slight change to your edge angle .
It matters not the blade steel , a performance increase is a performance increase .
This is part of my education , and anyone reading this is along for a free ride .
What am I learning ?
A) 22 degrees might be a decent starting point ( safe ) for a knife edge
B) Tightening the bevel a few degrees can seriously improve performance
C) Some steels can handle a tighter bevel , and some steels can not
D) The user has to chose an edge that will support the intended use for the knife
E) And if you dont try , you will never know
But that's just me , I have a thirst for knowledge and a box full of junk knives or knives I used to consider junk .
I never cared about this stuff 40 years ago .. The knife shaved hair = it was sharp ! ( End of story )
It was only after venturing into Chinese Knife Territory that edge retention became an issue .
I had knives going dull after opening a few envelopes .. ( What the parking lot )
So I got me a guided knife sharpener .. And the decent into edge retention began .
It's fascinating and annoying both at the same time .
The short of it is , good steel is good & bad steel is bad .. But without testing , how will you know ?
Oh well , killed off a few hours of my time today ! Learned something I did , so not a waste of time .
Education is never a waste of time .
