The old blade smith tradition can talk to us, should we listen?
First:
-I am an other old hobby smith
-I am not a metallurgist
-English is not my language (Shame on me, I do not even use the spelling check!)
-There are many facts and many blieves about techniques, difficult to position for sure as fact or believe
I introduce (can be too long intrduction?) a discussion topic, I hope to find interested smiths to share opinions.
I know that BG-42 or CMP-440V are more interesting to many as a discussion topic. To my mind the name of "The general knife discussion group" could be as well "The fancy commercial steel brand group", just a peronal opinion not a fact. I did find the same thing with computers, young people are interested about most new, commercial brands, things nothing to do with basic principles of computer internals. Some sense with this too. Old forging techiques are discussed 2000-3000 years before us and will we discussed probably next 3000 years. On the other hand BG-42 is discussed couple of years and will live perhaps many years ahead. Very parallel with computers- aging 3 years! After 2000 years not even the best books of history will know BG-42 ever exsisted. So, we have unique possibility to discuss about it? Also we can talk about BG-42, but the old tradition is something we must to listen too. Listening is more difficult than talking.
I would prefer to focus on bare carbon steels and low alloy steels as 5160, 52100..... Generally speaking the steels easily to handle and HT without new fancy tools as electrical, vacume,.... ovens. (Still also very fancy new steels can be handled with old methods at some extent for exampe so called "austenite forging".)
Some words (at very vague popular level) about the terminology and concepts, written "newbies" in mind:
-The problem that the same part of a steel can't be very hard and very though at the same time is unsolvable. There is a "trade off".
Smith's solution to this problem is that the edge part is hard and the spine though. No solution offered by super alloys (well, they are brittle whole time mostly).
-Austenite is a form of a hot steel to be hammered (all alloyed elements are a kind of unorganized, free, if you wish)
-With quenching (very rapid change from hot to cool) we change this form to very organized structure (tied in a way, matrix) which is very hard and brittle called martensite
-With tempering (warming some amount) we give up a little bit about this organization and get more though steel, also more soft unfortunately.
-Let's imagine you travel with a time machine to the middle ages with a sword made from BG-42. These unlearned people out there will laugh at your brittle sword made from a new high tech alloy of our modern times! (I just try to make my point clear at easy popular way, I know nobody is suggesting to make a sword from BG-42 to day). I mean new alloy is not a solution to all problems.
-Most common misunderstanding is that the overall hardness equals the cutting ability. The cutting ability depends many things as the fine crystalline stcructure and cutting hard sharp carbides
-The steel hrdness is measured by Rockwell test (HRc)- examples: HRC 50, though spine, HRC 61-58 hard edge, wear resistant too, a high carbon steel directly after queching HRC about 67-64, very brittle
Examples: HRC 50- file bites easily
HRc 58- new fine file scratchs the steel
HRC 61- new fine file slides
HRC>65 the steel scratchs a little bit glass (from quenching, not tempered, high carbon steel)
-If you still decide to use something as ATS-34, BG-42 CPM-440V you should buy enough equipments, because temperatures are very high, steel are not forgiving, you can't measure for example the quenching temperature with a magnet.
-You should have factory specs about max HRC, quenching temp and tempering curves
-A commercial fine new brand of the steel do not make a good blade, smith's work do
Infomation is available even in Internet, books are better. For example you can seek from internet terms: quenching, tempering, annealing, normalizing, austenite, martensite, perlite, bainite, crystalline structure, grain size, carbides, .....
To my mind a blade smithing book with a chapter of elementary metallurgy is the best.
Second best is a book with a name as "elementary basic metallurgy"
I do not know, is my terminology course useful or stupid.
Please, comment to this thread.
Random opinions about blade forging:
-A metallurgist of my steel supplying company said that if we cut the steel stripes from a sheet in the roll pressing moving direction (I do not know the right word), forging do not help (Indicating it helps sometime! We do not know it or it never even existed)
-Ed Fowler suggest lot of forging from big pieces downwards to get better more fine structure
-Jim Hrisoulas suggest perhaps odd things to many, aus-forging and edge packing (explained later)
-I did similar blades one just grinded from a bar and other edge packed and aus- forged from the same bar, HT and dimensions the same. I tested sawing against a copper bar and tested sharpness with cutting arm chair and sawingn leather stripes (Big difference, I do not tell which kind, nobody believes me anyhow)
Aus- forging:
Aus- forging is a very old German blade forgin techique (the term from a Jim Hrisoulas' book). Simply meaning, forge near the lowest allowed temperature. (Too low, blade is destroyed easily! ) The forging takes lot of time, the steel is warm enough only during few hits. On the other hand the grain size is not enlargening because the temperature is so low.
Edge packing:
Forge the blade shape roughly. Bend it edge down on the anvil horn as some semi circle taking into accout the lenght and thickness (difficult, no, challenging, yes). Start hitting with hammer peen inside circle. The blade will be eventually straighten, because inside becomes longer. This is supposed to creare a great fine grain structure.
I do not hit ever vertically on the edge, spine on anvil or on the spine, edge on the anvil to correct bending finally.
I had to build a tool for edge packing. I am clumsy, not able to hit at a precision of 1/32 inch!
Any opinions or experience about aus-forging or edge packing or other techiques?
Any questions about forging?
Your own forging techniques?
Please, start the discussion!
____________&
/_/----\-\---------/-\
./|_________________
| __________________|
|_|
(pig)
First:
Aus- forging:
Edge packing:
____________&
| __________________|
|_|
(pig)
