Just got an old (circa 1993) SE Military, like the one on the logo of this forum. Comparing it to the newer PE I noticed it has non-slip grooves not only on the top of the blade for the thumb, but also on the bottom, where my index finger might be. Really neat...
The blade was dull, and the tip was broken off somewhat, but after some tinkering the tip is like new, and the serrations can push-cut through cardboard with no problems. The scales were worn, but after a cleanup then knife looks great, even awesome considering it's 10-year veterancy status...
Now, to the real question at hand. The newer Millie is held together by three identical screws, thich look the same from both sides of the handle. The older Millie has similar-looking screws, but they are one-sided, with the heads on one side and nothing on the other. What's worse, two of the screws are too loose and won't tighten. Any idea if the newer screws can be used on the older Millie, and where these screws can be purchased?
Secondly, the clip on the knife is for two screws, not three, and again both screws don't hold the clip anymore. What's worse, the holes for the screws are spaced closer than on the newer three-hole clips, so I can't just drill the third hole and attach the new three-hole clip, unless I choose another spot for the clip. Any suggestions?
And finally, is there some way to order a three-hole Millie/Chinook type clip with screws so I can install it. Don't have a spare...
Still awfully impressed. That knife took a lot of wear and tear (and with my help it'll take even more) and it's still rock-solid, sharp, acceptably good looking and locks up perfectly after the cleaning and tightening. One great knife, hands down...
