Good to know, thanks David. I may keep it at 15 for awhile.I thinned my 'Carbone' No. 08 down to something well below 25° inclusive (12.5° per side); and it may even be at/around 20° inclusive. It's VERY thin at the edge, and I've noticed, kind of fragile too for anything putting lateral stress on the edge. Also vulnerable to edge impacts against anything hard, when this thin. If I were picking a lower limit for it in general, I'd likely not go below 25° inclusive (12.5° per side). The steel is relatively soft in the 'Carbone' version; I think the INOX Opinel would likely hold up better at similar geometry. I thinned one of those to similar geometry, in more-or-less a parallel experiment with the two knives, and the INOX (12C27Mod) seems more durable.
David
When it comes to simpler steels of older days, stainless blades were harder, and while they held an edge better, they were harder to sharpen and more prone to breaking. With modern steels its impossible to generalize as you can pretty much find a steel to do whatever you need.The Inox is harder than the carbon? I would have guessed the opposite! Is that because they do different heat treats on the two versions? I though carbon steels were usually tougher than normal stainless (excluding modern super steels). Is it possible to generalize in this way?
I see. Interesting.
I didn't know Opinel used Sandvik steel in their Inox blades. Cool!
As a broad generalization toughness and hardness are a trade off.
Happy to be wrong when corrected by you 42! thanks for clearing that up.Actually, it was the reverse to start with. Stainless steel in general was developed in the 1920's and even by the 1940's it hadn't become commonplace. The stainless steels of those days were soft which is why we have the lore today of carbon steels taking and holding a better edge than stainless. Queen was the first company I'm aware of to use stainless steel successfully in commercially sold knives, but Buck was one of the first to bring a hard stainless blade to the market, and they're where the problems with sharpening and durability started popping up. Their old 440C blades were really quite glassy.
Hi,The carbon steel is tun prettybsoft. It will roll or fold at low angles. I've never measured mine, as I free hand, and also convex.
Their stainless seems to be run a little harder. Holds an edge longer, and can go a bit shallower on the angle.
I bet you could take it down to 10° or so. Just careful of putting any significant side loads on it.
Hi,
Opinel website says they aim for 57-59HRC ...
So,
Any guess as to what is "low angles"?
Cutting what when it rolls?
Equipment used to sharpen?
