The Perfect Knife for Me!
I need some suggestions for a daily carry UTILITY knife that fit these characteristics:
1. VERY Strong lock (Which type is strongest?)
2. Clip or drop point blade no more than 3"
3. Durable knife that will take/hold an edge
4. Light weight, thin handle that is comfortable to carry in back pocket
5. Price around $100
These are listed in the order of importance
Thanks for your suggestions.
Bill
Spyderco Delica fits all your req's, and you can almost get 3 for $100.
Spyderco small (C25) Centofante. 2 7/8" with an ATS-34 blade. Takes and holds a very nice edge. It's a very thin knife with textured G-10 scales. Great utility shape with a sharp point. Standard liner-lock with a backup lock called the 'secure lock'. This is a manually operated slide button which puts a pin into the tang of the knife. For a small knife, this adds a great deal of security. I'm not sure if you could defeat the secure lock with a lot of pressure.
It's comfortable clipped in the back or front pocket. I usually carry mine deep in my front pocket at work and don't notice it at all. For working around my shop I often clip it to my shirt just to keep it handy.
Don't be deceived by its size. It is a solid hard use knife. I prefer the plain edge model, but you can also get it fully serrated. About $90 at Internet retailers.
Microtech UDT... or is that illegal in the People's Republic of California? If it is, try a small BM Ascent. Lock back isn't the strongest in the world, but it should be enough for most people.
Chang the Asian Janitorial Apparatus
Given the fact that your 5 item criteria are in descending order of importance, I would get a small Sebenza and give in on item 5.
Failing that suggestion, resign yourself to getting 2-5 with perhaps not the very strongest lock of all, but a great knife as to your criteria 2-5: WEGNER, JR.
What will you be doing with a lightweight, easy to carry folder that makes your number 1. #1?
I say that because the strongest lock is a fixed blade and your prioritization of number one may need to yield to satisfy 2-5 superbly.
Conversely, 5. could yield to 1. and we are back at the small Sebenza.
[This message has been edited by Nimrod (edited 08-02-2000).]
Warthog... Since the money was at the end of your list of importance, you might want to look into the small sebenza by Chris Reeves.
GOOD LUCK!
BC... For those who fought for it, Freedom has a flavor the protected will never know... Semper Fi
...OR you could buy a pair of Small CRKT Kaspers! (That way, you can give one to your wife/girlfriend), and still have enough money left-over to take her out to lunch.
Dann Fassnacht
Aberdeen, WA
glockman99@hotmail.com
ICQ# 53675663
[This message has been edited by glockman99 (edited 08-02-2000).]
Spyderco: Native, Delica, Walker...all qualify, all are great. You can't go wrong with any of them, or with any Spyderco.
Second BM705, since you want a very strong lock. The Axis is among the strongest, and is fully ambidextrous, to boot. 2.9" drop point blade of ATS-34. I don't know what is lightweight and thin, to you. I have no problem with it.
--JB
e_utopia@hotmail.com
I'll also recommend either the BM 705 or the Spyderco Centofante Jr. (C25).
The Centofante Jr. is my favorite: it's thin, comfortable both in the hand and in the pocket, the flat ground blade takes a wicked sharp edge, and lock up is as solid as you'll find anywhere. Only negative I can think of is that you really can't clean your fingernails with this blade -- the point is too dang sharp!
The BM 705 offers the great Axis lock and is truly ambidextrous; even without moving the clip, I can open and close it easily with my left hand. The BM 705 only weighs a little bit more than the Centofante Jr., but it is noticeably thicker; however, the thickness doesn't seem to affect how comfortable it is to carry. Blade has a sabre grind. Mine came shaving sharp from the factory and I haven't had to resharpen it yet, but I'd have to speculate that it will not be as easy to sharpen as the Centofante Jr..
Dave
Signature line needed. Apply within.
Native or BM 720 (1/4" over your blade limit, but a great, solid knife you should take a look at.)
Brad
Thanks for all the suggestions. I will look at all of them before deciding which one to buy.
RH - I've been carrying a Delica for the past 6 or 7 years. Just time for a change.
Nimrod - You're right, a fixed blade makes perfect sense. Except here in the PRC my Little Camper could be considered a "dirk or dagger" if carried concealed. As I understand the law, if it folds, it can't be a dirk or dagger.
I want a strong lock because I believe in Murphy's Law, and being an old guy, I heal slower than I used to.
Thanks again.
Bill
This suggestion will not comply with your 5th rule but it will with your 1st. The new Schrade Lake/Walker, has the new "tough Lock" which is suppose to be a new locking mechanism, and is suppose to be really strong. But it costs about $200. I have not personally tried it yet. Also there are only 1,000 available, so it will make a nice collectable.
THANKS!!!
-NAN-
-WAR ALONE KEYS UP ALL HUMAN ENERGIES TO THEIR MAXIMUM TENSION AND SETS THE SEAL OF NOBILITY ON THOES PEOPLE WHO HAVE THE COURAGE TO FACE IT -BENITO MUSSOLINI-
Hey Warthog: good choice! Paracelsus, though, now has me thinking about a Centofante.
Hoodoo
And so, to all outdoor folks, the knife is the most important item of equipment.
Ellsworth Jaeger - Wildwood Wisdom
