Balex
Banned
- Nov 7, 2003
Hi,
like you guys know,I just purchased a LM Pulse. The pusle is was the almost perfect multi tool for my needs...until today when it became perfect!! All it needed was a simple yet tricky modification:
Adding a metal saw without removing any other tools.
It was a success!
(I know I just terminated my 25 years warranty...ask me if I care
Next modification: Adding a pocket clip!
wish I could post a pic but it seem's that this forum wont allow
Email me and I will gladly send a pic.
edited 08/09
First I got the screw unscrewed using 2 vice-grip plier, gripping each screw very firmly. And let me tell you that they(screws)are super hard to unscrew!!
When I finaly got them out (screws) of the handle then all the tool,2 small washers and locking piece fell on my work bench! I got a bit worried...but Leatherman tools are as easy to put back together then legos
I did not change anything about the order of the tools originaly...So first came the:
-bottle/can opener back in
-then the Phillip screwdriver
-super small flat screwdriver
-then my mod metal saw*-one small washer
-metal/wood file
-and finally the awl
note: the remaining washer was not use I dont think it would have fitted back in
To build the metal saw, I took a usual metal saw blade,cut it about the same length as the metal/wood file.
Then I enlarged the hole of the metal saw (using a drill) the same size as the rest of the tool so that it could fit in the handle screw I had removed. I rounded the end and then I put the metal/wood file on top of my little (now cut down and rounded up) metal saw and used a marker to trace the shape of the tool. I used a grinder (you can use a file also) to grind the metal saw the shape of the tool but ONLY grind the end piece where the tools lock and not the whole shape of the file cause you will have a hard time getting the metal saw out once put back together!
I them made a notch the same size as the rest of the tool so that my NEW metal saw can lock like the rest of mu pulse's tools.
I finaly put it all back together like mentioned in the top page.
Have fun!
It was a success!
edited 08/09
-metal/wood file
Have fun!
