- Aug 9, 2021
The new Rail Height Adjuster for my Hapstone R2/V8 just arrived from Gritomatic. It makes setting the bevel angle very easy. It replaces the original vertical column and fine tuning adapter, which worked OK, but were rather fiddly. With the new Rail Height Adjuster, you just turn the orange knob at the top, and the pivot for the rail goes up or down very smoothly and stays in place, like on the Work Sharp Professional Precision Adjust. This makes the Hapstone easier than the TSProf Kadet for setting the angle, and almost as easy as the WSPPA or Kazak Model 100.
The Rail Height Adjuster is also more rigid than the original vertical column. And it has a new parking mechanism that I think is better than the old one.
There seems not to be a thickness compensator, but that's not really needed because it is so easy to reset the angle as desired.
I see no instructions for installing the Rail Height Adjuster. Look at the photo on the Gritomatic web site to see what it is supposed to look like. (Hapstone-USA does not have it on their web site yet.) The only tricky part is that you first have to unscrew the hex screw from the base of the Rail Height Adjuster, remove the base from the vertical column, screw the base onto the platform of the R2, put the vertical column back on the base, and replace the hex screw.
