The razor edge?
Has anyone ever used products from the razor edge? if so were you satisfied?
They do quite a bit of bragging on there website so just wondering if their product is in fact as good as what they're saying it is.
I have both sizes of the razor edge knife clamps/guides. I was interested in this system because I had a large collection of bench stones (DMT and Arkansas) that I didn't want to abandon for a rod-guided sharpening system. I also prided myself on my free-hand ability with a bench stone, so the razor edge system seemed to complement the grinding style of bench stone sharpening. If you have bench stones already, the clamps are cheap and work well.
The razor edge system works best with blades that are 4" and shorter. Long blades require repositioning of the clamp. I use the small guide far more than the larger guide.
It takes some practice to get the clamp adjusted and in the correct spot on the blade but once you figure it out, you can grind a constant-angle edge. The guide/clamp also gets ground on the bench stone and slowly wears away, but you will learn to put more pressure on the knife edge and let the guide just glide on the stone. I've had mine for 10 years and they are still good.
I separate sharpening systems into two basic types: fixed angle systems (razor edge, Lansky, Edgepro) and free-hand systems (sharpsmaker, 1" sanding belts, paper wheels). The difference comes down to precision. The fixed angle systems grind a constant angle/edge with no rolling. With free-hand systems there is a tendency to alter the angle with each pass and the ground edge becomes convex (rounded). I use a sharpsmaker, paper wheel, and 1" belt system for kitchen knives and a quick touch up on my EDC. The sharpsmaker is quick but requires that you hold the knife vertical as you swipe it past the rods. I use it for knives that get abused (kitchen cutlery) and workbench fixed blades. For expensive, hard steel personal carry knives, I use the razor edge. It take more time, but you get a better edge. The razor edge is the best for reprofiling.
One criticism with the razor edge is that the angle changes each time you sharpen because it it not possible to position the clamp in exactly the same spot on the knife each time. This is true, but doesn't seem to be a big problem. I watch the grind (using a jeweler's loupe) and if the guide is wrong you will see that the edge is not getting touched. Some people use the felt pen marker on the edge to see this.
If you have some bench stones already, I'd recommend getting the razor edge clamps. The "kit" they sell is sort of disappointing because the so-called hones are really a block of wood with peel-n-stick sand paper that you attach yourself to the wood block. If you are looking to set up a sharpening system from scratch, get the diamond Lansky.
Id like to ask a second part to the question on razor edge. Has anyone used their sharpening service I was thinking of sending in a few knives. Thanks for any info
I have the Razor edge. I find the Lansky worked better for this type of sharpening. However the Razor Edge system does work and the guides actually trained my hand (kind of like training wheels on a bike) to maintian a constant angle.
The Razor Edge system actually weaned me away from using angle guides. I was able to get a better edge freehand after my experience with the razor edge. I now do most of my sharpening freehand using spyderco rods alone (minus the angle supporing base) to gently hone my knives. I did use the razor edge stones but they wore out.
Also the Razor Edge sharpening book is kind of simplistic and I heard outdated, however it still does give a lot of good tips and info. I think the guy is a very talented in the area of sharpening and used that to advertise a functional sharpening system that to me is by no means unique or revolutionary.
Razor egde sharpening stones are good but like my lanksy they also wear out I don't know how much they cost individually but my kit was quite expensive. If you do a lot of sharpening the guides are going to grind down eventually because they are scraped across the stone with the blade, there is no way around that even if you do put the more pressure on the blade, the guide still has to drag.
That being said trying to keep more pressure on the blade to preserve the life of your guide seems to do wonders in training your hand to maintain a constant angle I would definately advocate this kit as a stepping stone to freehand sharpening.
Sending knives in the mail is always a hassle, and getting more expensive every day. Save your money and invest in a sharpening system that will serve you forever. Sharpmaker or Lansky are inexpensive, easy to store, easy to use, and work well. Shipping + sharpening service will cost you 1/2 of a entry-level Lansky.
Look at the DMT Aligner diamond sharpening systems. They are significantly better than the Lansky, Gatco, etc. and don't wear out anywhere near as quickly.
NJ
