- Aug 1, 2000
Hello Again,
Thank you all for the input on my <a href="http://www.bladeforums.com/ubb/Forum51/HTML/001370.html" target=_blank>first
grinder posting</a>! I carefully read them over and over. "Thank
you" to those who emailed photos and faxed parts lists and exploded
views of various grinders.
I just can't believe the prices for some of the grinders on the market
and it makes me think that there has to be another way than to dish out
$1000-$2000.
<center>
Based on input, I've come up with the second iteration.
<img SRC="http://www.geocities.com/beaumontmetal/sq_wheel/frame.gif" NOSAVE BORDER=3 height=415 width=705></center>
It starts with a basic frame made of commonly available steel pieces
bolted to a heavy workbench top. The riser plate (mounted between
2 angle irons) accepts a contact wheel setup or a square wheel setup. The
arbor for the contact wheel is shown in red above. The belt tension arm
is spring loaded and adjustable in length to accommodate different setups.
The tracking mechanism was basically copied off of a band saw which has
an adjustment knob to tilt the idler wheel, shown below.
<center>
<img SRC="http://www.geocities.com/beaumontmetal/sq_wheel/tracking.gif" NOSAVE height=157 width=223>
Here are some clickable links to view more:
(they should open up in a new window for convenience)
<a href="http://www.geocities.com/beaumontmetal/sq_wheel/square1.gif" TARGET=_blank>square
wheel setup</a>
<a href="http://www.geocities.com/beaumontmetal/sq_wheel/squarsetup.gif" TARGET=_blank>square
wheel details</a>
<a href="http://www.geocities.com/beaumontmetal/sq_wheel/contact1.gif" TARGET=_blank>Contact
wheel setup</a>
<a href="http://www.geocities.com/beaumontmetal/sq_wheel/10contact.gif" TARGET=_blank>Contact
wheel details</a></center>
I think I've overcome some of the major downfalls of the first design
and still kept this one simple enough that many people can build it at
home. Let me know all of your thoughts and if everything looks OK
I'll start building one to play with.
Sincerely,
-Rob
<a href="http://www.geocities.com/beaumontmetal/index.html" target=_blank>Beaumont
Metal Works</a>
$1000-$2000.
<center>
<center>
wheel setup</a>
wheel details</a>
wheel setup</a>
Sincerely,
-Rob
Metal Works</a>
