Cliff Stamp
BANNED
- Oct 5, 1998
The largest problem is probably just angle consistency, however there are many ways around that, using a jig or simply a marker on the edge. The biggest problem I have found is with the inherent damage on heavily used edges, which leaves the edge formed with weakened steel. The damage can be corrosion, but usually is fracture from impacts or fatigue.
Recently during some comparitive work I had noticed my sharpening results much more positive than usual. After some reflection it was obvious that this was due simply to more work being done on the edge. They were being examined under magnification [x20], and completely sharpened until all micro-bevels were removed, then given one more round (1-2 minutes) just to make sure.
Under this method I was seeing shaving edges with 1000 grit waterstones. In contrast the last time I tried to sharpen the Camp Tramp, I could not get a decent shaving edge even though it had a burr (cut off), then finished right up to CrO. The problem was that the knife had been used really heavily (a lot of throwing, and other heavy impacts, really gave the tip and edge a pounding).
This problem can be hard to notice because the edge will form well in regards to burr, catch on finger nail, even looks decent under magnification, however the sharpness will be low, and the edge retention worse. The only way to solve it is to recut all the weakened metal, and the only way to tell that this is happening (outside of really high magnification) is to see a sharp edge forming.
Nothing really new here, but as a possible solution, the next time you have a knife which is really refusing to take a sharp edge, go back to the most coarse hone, form a full burr, cut it off with a few strokes at a higher angle, then go back and remove this micro-bevel, repeat this a few times until the edge is shaving decently well even on the coarse hone. This is possible even with x-coarse DMT, and 100 grit AO belts.
The other well repeated point is that don't let knives get so dull in the first place. The more you sharpen the easier it will be as you will be preventing excessive damage.
-Cliff
-Cliff
