The size of the lanyard pin?
Have a piece of stainless steel,want to make a lanyard pin for my small regular Sebenza.Want to know the dia of the hole for lanyard,or the inside dia of the pin.Thanks!
The lanyard hole on my small regular is 4mm
If you have a lathe you could make either side of the pin 4mm to fit in the holes with a 5mm or 5.5mm "core".
That would mean you can have the pin in there with no lanyard if you so desired.
The hole for the lanyard will need to be 3mm though as the gap between the scales is 3.5mm
Hope that makes sense :confused:
:thumbup:
Curious...Are the lanyard holes on all Sebs the same size? If so couldn't you just order the Umnum lanyard pin. Understanding that the ends would have to be filed for fit.
