Recently made two small edc knives from 80CrV2. All went well and I was a happy cat until I started heat treating them.
I have tried multiple protocols for 80CrV2, but I personally have had quite good and consistent results using Larrins recommended protocol which you can find in his book and also on knifesteel nerds. So far so boring, 80CrV2 is a quite forgiving steel in my experience, but these two knives just wouldn't harden, like at all.
Did some thermal cycling at 850C° for 15min and then at 815C° and then tried hardening again, but to no avail. I used some anti decarb to protect the blade during the process and ground the blade further before checking hardness.
I am not sure what exactly went wrong. I've heat treated a bunch of 80CrV2 with Larrins recommended protocol with good results.
My only guess is that I've either got a bad batch of steel or this bar came in a state which needed higher temps in thermal cycling? I don't know, I've scrapped the blades and started over with another bar of 80CrV2 which hardened just fine (I made a coupon and checked that one beforehand).
This is me just basically venting a bit and saying don't change your supplier. Because the bar that gave me trouble came from another suppler than I usually order my 80CrV2 from. Also that bar, which gave me trouble, strangely had a very thin hardened layer on the outer edges of the steel which my bandsaw couldn't really bite into, I had to make a notch with my anglegrinder and then I could saw into it....I've never seen that before.
