- Oct 23, 2006
Hey guys,
Andy and I were talking about this grind I've been using on my "utility" type knives. I call it a "standard" grind because that's what I put on a knife when a customer doesn't specify what type of grind they want.
Basically it's a convex Randall grind.
Here's what it looks like.
Here's the theory behind it:
For the last year or so I've been trying to come up with the super knife. Like (I'm sure) every other maker before me I came to the conclusion that it's not possible to make such a knife. There are specific grinds, stock thickness, blade heights, profiles, etc. for specific chores. This grind is the compromise I settled on. It does most things well but does nothing exceedingly well.
So the point of this thread is to start a debate of your thoughts on the benefits or detriments of the grind. I'm interested in everyone's opinion, good bad or indifferent.
Sorry for the wordy post.
Thanks in adavance,
Iz
Advantages:
The low grind height near the ricasso area is very much like the 1/4 height grind, meaning it's super strong. This is an advantage in a woods knife as much of the notching/carving work is done right in this spot. The middle of the blade has decent height for slicing but still enough metal behind the edge to be an excellent batoning knife. The tip, with it's full height characteristics, excels at slicing when skimming off extra wood or slicing potatoes around the campfire. I prefer this grind over all others for a general/hard use knife. It just can't be beat for utility purposes when used correctly in my opinion.
Disadvantages:
Only one that I know of, the tip isn't as strong as the 1/4 height grind. But with a little common sense drilling with the tip is no problem at all.
Thanks in adavance,
Iz
