On first picture is my worn ceramic platen glued with double tape .As you can see tape was heavy burned from heat because tape is insulator .Pure epoxy has low thermal conductivity .Real one thermal epoxy are very expensive .Close is JB weld for what i need but it is mix with iron dust as far i know . So what if i mix cooper or silver fine dust with epoxy ? What do you think , it can be only better ?Maybe there are other better solution for this ?
I have mounted aluminium heat sink on back side of flat platen and i will use this thin tungsten carbide plate .It is very thin / 1.2mm/ so it is good if i have faster heat transfer from TC to platen and cooler ..............I grind on very high speed and lot of pressure so there are very high heat on platen .I hope TC will lower heat little because it has low friction characteristics but ....
