Dan, I didn't know HTT&R carried TC's and such?
kdnolan,
You need a:
8 or 10 gauge type K thermocouple
Ceramic sheath to put the TC in
Something to read the output of the TC - usually a simple PID
This TC kit will have all the TC hardware:
https://www.ebay.com/itm/High-Tempe...926894&hash=item1c98dcc849:g:YMAAAOSwI-BWLnxj
This read the temperature (save tghe SSR and parts for future PID control):
https://www.ebay.com/itm/PID-REX-C100-Temperature-Controller-SSR-40DA-K-Thermocouple-Heat-Sink-Kit-USA/124332230550?_trkparms=ispr=1&hash=item1cf2c74796:g:Y1wAAOSwiKpfSNcz&amdata=enc:AQAFAAACYBaobrjLl8XobRIiIML1V4Imu%2Fn%2BzU5L90Z278x5ickkp2NA0WuhQytmt4dbStg00F8bIDZPibHv5FFpEF6eaZGrH0VjMnhv97e1qbp%2FbptV%2Bu0ngjJsPkkErH6psrHgY0KjXjQxKwJDwVt%2BedRHWIgKCeK8anfsfXzY24vojrPVtRSmHKjGXpuoiAVyXRY%2FmN%2FTq%2BnaaTh%2FVM%2BSkOLusPoxaHX9zRENvg1bWjM8V1rSP3J1vmjNtNeNF68cQ5hZLUuD7pFHu6o0t%2BCVxdai2%2BuxQYN3phiFfJ%2BlxlBzFG0kcU1tNM0ng%2BHnPAq9wHcNLPb6dsnl5flR0W2jUqGrDsjE4H3GICeIB3%2BpQZxoWDdp6DxBPRBGX7phArsSFJgHpwxMRgCYpzdzo%2BOYUKoVmrngYcNxdoEQCdeSYNf98vJJ5kPZn%2FqhJiiwDGMuZPrFYZRV%2FWcmYrfOkr7NeyguI4kyvW4fjdDOLhFz5AYT5hHEK7lP0t6SJDX5iB3gzwIsg6uBIPj7Lr%2FpU6oJbRqSRf2P3gny4HBGMvyg15qcFZN2Hu9TlE%2F5qtbBcX2xtwpaJO07XuYf74Yvo5R%2BXny8lLxAnjx7SBmIUNC0nl%2F84X004Fh4fGhemBtWzY%2BXcLKADTjLttw%2BZIZG4hRtbJvYICQSVJE9jiKRGD%2BbST5gi5dHNDBT58u3JmbjmjhYbMQmpRZx%2FTj9w5lIMZMJknP8V9sGxR5%2F4TE97XV%2Bxc39JD2asqvjhfD%2FvKdwbYkzMdRvlnIxCH1Nw0nH4hubQR88wZQy6972hvzguW0fM7IJ3jYm|cksum:124332230550a18d76da11684b5c862440a8c8951c66|ampidL_CLK|clp:2334524
Hey Stacy, I know this is an old thread, but I’m looking for a replacement TC as the wires on mine burnt up over time. I’m struggling to find exactly what to look for and the link you posted is no longer available unfortunately. If you could help me out it would be much appreciated!Dan, I didn't know HTT&R carried TC's and such?
kdnolan,
You need a:
Ah sorry I forgot to point out it is for a forge, would either of these be decent options?I'm not Stacy, but if for an oven you might try this item in ebay, just do a search on item #314153500374 and it should pop up for you.
OR, perhaps even better go to auberins instrument, paste item #TC-K-KLNSHl (just the item number) for a solid ceramic sheath and TC.
Would you suggest 6” or 12”? Is there any negative to getting the king option? Thanks for all the helpEither will work for a forge, but the Auber Instruments until with the solid ceramic sheath will be a good bit better. A forge can get so hot even the solid ceramic sheath needs to be kept out of direct flame. Best to have just the tip sticking thru, and even perhaps sliding tip back some once the forge is stabilized at a temp for a longer lasting ceramic sheath. A quote from the Auber's page: "this product can handle very high temperature (up to 2700F) but it cannot touch the flame directly"
Also note that link is for the sheath only and does NOT include the TC. The TC is Auber's # TC-K-KLN for the TC. This TC does have a ceramic covering, but not the solid sheath needed for a forge.
There appears to be no price difference whether is 12” or 6” for both the tc and the sheath on the website you suggested so I suppose I’ll go with 12” thanks!I would tend to go with the 12" option to keep the wiring more distance away from the forge. 6" will work, and might be plenty. Wait, are you talking about the solid sheath as 6" or 12"? 6" should be plenty as the TC can stick out as far as you wish.
On the segmented ceramic sheath - it will work, but doesn't provide as much protection for the TC wire itself, but when using the #8 wire it's pretty sturdy. AND - "IF" you slide the TC back out of the forge after forge temp has stabilized it will last a long time I'd think. Now, with a 2 brick forge, I don't have a clue about those - does it have a regular burner? OR, is it using a propane torch?
