"Thick" blade owners....help!
Bought a short Kabar...handles a little short, but I look forward to getting some user time with it.
Took the top guard off, took the powder-coat off the....umm the BIG bevel. (Still not sure which is considered the primary and secondary bevel. To me it makes since that the BIGger bevel is "primary" but I've read a few posts which seem to say otherwise.) Got the big bevel polished up and in the process took of the deceptively sharp edge it came with. (Didn't "feel" sharp but took hair off effortlessly.) I have two questions:
1. Is it typical of factory knives for the last 1/4" of the point to be sharpened at a much more obtuse angle? Seems I've ran across this a couple times...always considered it slop. I suppose it serves a purpose. But lets not "pry" too deep into the issue:D Is it typical?
2. This BIG bevel is already at 20* And this is usually the highest I set my blades to. I realize that this is 1095 and not a "skinner" blade profile or thickness. I can't hardly bring myself to raise the secondary bevel to nearly 35*. How do you fellow knifenuts address this issue? Are you still satisfied with an obtuse edge or do you strap-in and work it down? If so, do you have any pictures.
I realize this is a utility blade and, like I mentioned earlier, not meant to do the same tasks a skinning or paring knife are asked to do. Still, a knife that won't shave is a knife that's likely to not get used. (By me at least:rolleyes:)
I think I can say that most of the sharpening nuts here routinely thin out the often thick factory edge geometry on their users. If I'm going to use a knife, I will sharpen it until I'm satisfied, regardless of how far towards the spine I gotta go to get it thin enough. I use mine to chop wood & brush mainly.
I don't see any reason why you shouldn't be able to get it to shave and much more. I have a ratweiler (1/4" thick) that I put a 15 deg. primary on with a 20 deg. "micro" bevel that will shave like there's no tomorrow - and I am by no means a sharpening "kung fu master" like most that frequent here. I think most knife nuts, as stated above, thin out their sharpened pry-bars to make them resemble more of a cutting tool. I can't see any problem with it as long as its good steel with a quality heat treat. I beat the crap out of my Ratweiler on everything and have done nothing more than slightly roll an edge here or there.
Imagine you've going to make a knife. Which bevel will you have to grind first? That's the primary bevel. After you've finished making the knife you will sharpen it, and that will create the edge bevel or secondary bevel.
