Firstly, I need an advice regarding the minimal thickness of an O-1 edge before heat treatment. Since I'll be using handtools exclusively for this knife I really want to go as thin as possible on the edge/grind BEFORE heat treatment. The heat treatment will be taken care of by a firm specialized in this for industrial applications. The O-1 blade will NOT be cryo treated and NOT selectively tempered.
Secondly, which levels of HRC do you recommend for a knife made from O-1 tool steel for:
4-5" blade; optimized pure cutter for meat end wood, full flat or full convex grind.
8-11" blade; optimized wood working chopper, full flat primary and sub mm secondary grind or full convex grind.
Thanks,
VIKING DK
Thanks,
VIKING DK
