- Sep 13, 1999
In his book "The Pattern Welded Blade",p.17, Jim HRISOULAS writes that very thin (0.003 to 0.005 inch) high carbon shim stock can be welded to either low-carbon or pure nickel shim to form a damascus billet. He says he started with as much as 250-350 layers.
Among others, the advantages of this method are a reduced need for folding and welding, and a more even pattern in the finished blade.
I thought I could try this method when I found some used and/or broken large metal saw blades about 0.004 inch in thickness that could make a nice billet whith either low-carbon steel or nickel.
Then my questions:
1) Has anyone an experience with thin layered damascus?
2) What kind of steel are these metal saw blades made of?
3) Jim HRISOULAS says that high-carbon shim stocks can be welde with low-carbon shim stocks OR pure nickel. Does he mean that you can alternate high-carbon and nickel in a, say, 50 layers billet? Isn'it too much nickel?
Thank for answering...
Claude
Then my questions:
Claude
