- Dec 23, 2008
After reading a post by Quy4n8 about thin blades, I decided to make a post to find your prefrences about small thin blades such as Peanuts, small toothpicks, or 2" blades in general.
I just made a peanut using a 1/16" stock, pretty thin, but the same thickness as a case peanut. However, it's a touch longer and it is 1/2" from spine to edge where as a typical peanut is 3/8". This wider blade allowed me a more narrow angle geometry and made a really mean slicer. The downside is that it has quite a bit of flex.
So if you are carrying a small slicer like a peanut would the flex bother you? Obviously a 2" blade has limitations and isn't meant to perform every task.
So I would like your opinion and also, if you carry a peanut, how many of you also cary a second larger knife on you? What do you use your peanut for?
