I found out an amazing fact, a well sharpened pocketknife is actually *sharper* than a utility knife....
i took my Spyderco Cricket, Kershaw Scallion, Spyderco Harpy, and SAK Spartan Lite, and a brand new, out of the package utility knife, and a standard 8.5x11 sheet of 20# bond copier paper in the portrait orientation
starting at the top, using only the weight of the knife itself, i cut downward thru the paper, pulling the blade towards myself, the cut stopped when the point exited the paper....
brand new utility knife; 1" cut, very ragged edges
Kershaw Scallion plain edge assisted opener; 2.5" cut, clean edges
Spyderco Cricket plain edge; 3" cut clean edges
Spyderco Harpy serrated edge; 5" slightly ragged edges, but cleaner than the utility knife
Victorinox Spartan Lite Swiss Army Knife;
small blade; 2.3" cut, *exeptionally clean* cut, *no* tearing
large blade; 2.7" cut, *exceptionally clean* cut
i also did two other tests, the "fingernail drag" test;
all my knives had a draggy feel on my thumbnail, the utility knife did not, the utility had no resistance
the final test was the "shaving arm hair" test;
utility knife; did not shave at all, pushed hairs under
Spyderco Harpy; what, are you *INSANE?!?!*, use a *serrated* knife for shaving, NO frakkin' way!
Spyderco Cricket; the "Reverse S" blade makes it dangerous to use for the shaving arm hair test, this one was not tested
Kershaw Scallion; this one shaved quite well, not hair popping, but it did cut hairs
Vic Spartan Lite; (both blades performed the same), this one *did* pop hairs, while shaving my arm, the arm hairs jumped about 2" into the air as they were severed by the blade...
all my knives have been sharpened on my Spyderco Sharpmaker....
hmm, that gives me a *crazy* idea..., i'll sharpen the utility knife on the Sharpmaker tonight to see if that improves it's cutting ability.....
