I have a couple questions to the sharpening inclined around here. The blade I am talking about is S30V. I have a smiths guided system with diamond hones and I used it to sharpen and reprofile the knife. I know this isnt perfect but its what I have and works good for me for now.
Basically when I try to shave hair when I try to shave down my arm it will shave hair but when I go up my arm it does not. Is this due to uneven sharpening?
After done with the guided system I was still wanting more so I freehanded it on the hones they provided 750, and 1000 grit and saw improvements but still have the above problem.
Basically I am asking the above question. Also I noticed that one bevel is a bit larger than the other so I assume they are different angles, (almost positive from eying up the edge). Should I fix this before trying to fix the other question?
Just for your info I normally maintain my knives by stropping on 2000 grit sandpaper or 800 grit if its bad.
