I've been looking into purchasing a grinder but the 'want' (kmg) factor is pushing the thing a bit higher on the cost scale than I really want to go at this stage in the hobby. So, thought I'd check into building one.
Belt grinders look fairly straight-forward to build and even though my skills are a bit rusty after a lot of years away from metal working, I think it's well within my abilities.
Anyway, what I'd like to ask a few questions about is idler/tension pulleys.
Years ago, i used an item that was basically a stud that was held onto an idler arm with a nut. The shaft had a bearing built into it for the idler pully to turn on. The outside sleeve of the beaing had a threaded end on it to hold the pulley on the shaft. For the life of me, I can't remember what these things were called. Thought a google search would turn up something to remind me but it didn't. Can one of you get me going in the right direction as to what these are called?
second, can anyone point me in the right direction concering idler/drive wheels that will work for a grinder.
If this doesn't pan out, I'll return to the coote/grizzly debate I was having with myslf again.
Thanks....Curt
Thanks....Curt
