Thinking of getting into kydex bending.
Hey guys,
So I finally decided to buy a house, and along with the terrifying responsibilities I now have there are some positives, I will finally be able to set up a little workshop. I've been searching for a Canadian kydex sheath maker for some larger projects and ov come up short I can't seem to find anyone up here so why not give it a shot? I've made a few smaller sheaths with almost no tools so maybe with some practice and some better equipment I could start churning out some nice stuff.
What I'd like to know is any tips and tricks or unique tools that make sheath making esker or just a better product.
Here's what I know I'll need.
A kydex press (I'll probably make my own either out of some thick plywood or steel)
Drill press
Arbour press
Eyelet dies
A belt sander
Heat gun
Dremel (for making slots)
Thanks for any help guys.
Although a heat gun is useful a good toaster oven, or pancake grill, or a T shirt press will be more desirable/practical.
Oh I should have mentioned i will probably be using my regular oven for the heating if all goes well I'll invest in one of those fancy t-shirt presses.
For large batches or really just more than one a heat gun gets old get a toaster oven and a non contact thermometer or a shirt press also get a bandsaw you can do with out these at first but if u really get good at it they r a must your going to also want a respirator of some kind for use with the belt sander and I would not use your kitchen oven as when you accidentally burn kydex it puts off toxic fumes
James W.
And also post some pics here of your work we all love pics and maybe we can give u some advice
I was thinking of a bandsaw I figure I'll putter along without it until a deal pops up on kijiji or something. Maybe I'll grab one of those cheap griddles for heating until it makes sense to spend money on a shirt press. I'll post some pictures when I, home and can take some they aren't much but it's a start I figure.
Careful with griddle selection. I found that the cheap "Presto" brand ones at Wal-Mart (think I gave like $20 each for mine) have worked great. The "Rival" brand ones I bought were no good. The Kydex would stick to 'em.
Thanks Kiah, a good counter to that issue might be to put a thin sheet of silicone on the griddle, but hopefully I will find the presto ones.
Tee shirt press is the best if you can afford. I have done over 1000 sheaths with a toaster oven. I got one that can fit a 12x12 sheet in it. For bigger I use my oven.
We use the same walmart griddle. I like it much better than the oven
