I was thinking about maybe picking up a Native from Wal-Mart to try to thin it out at home, using maybe a dremel? Would this be possible, or would it need to be sent off for such work? I don't have any knifeworking experience.
Just go to a skateshop or bikestore selling boards and ask for a sheat of grip tape. Cut it into sections and put a piece onto a flat piece of wood. Once it gets worn and full of ground off steel, take it off and put on another piece. It works great for this type of work.
As for the angle you should use, if you're going to thin it out, why not just go flat to the stone? Really easy to keep a consistent angle that way.![]()
There is a common misconception that lower angles mean increased frequency of sharpening.
-Cliff
What exactly are you doing that degrades the edge so quickly?
I don't think it is a misconception.....it think there are so many factors to consider that it boils down to knowing the work you'll be doing and putting the knife in the best condition to accomplish what needs done. I do a lot of heavy cutting and a thin edge (on my EDC) just doesn't hold up as long for me.
You can still go flat to the stone and microbevel to a more obtuse edge angle. I went flat to the stone and 15 per side microbevel and it was plenty durable. You could always go with a 20 per side microbevel if you are having trouble at 15 per side (the factory edge on mine was about 12.5 per side). Are you cutting metals, those would definately call for a more obtuse edge? I know I have found my edges to last longer when they are more acute, but if you are chipping out the thinner edges with your work you obviously need to go more obtuse. However, I would say for the most part the average user would be sharpening less, not more, with a more acute edge, and a flat to the stone Native is a lot more durable than a straight razor unless you have a bad heat treat. One of my EDC's right now is a Caly Jr. ZDP thinned to .005" above the edge, sharpened at 5 per side with a small microbevel. It hasn't touched a stone in a couple weeks, but after cutting up some cardboard, rope, plastic packaging and various other things over that 2 weeks it is still cutting very good and shaving with ease. I think you are selling short the benefits and actual durability of acute edges for lighter/medium duty work.
Mike
cutting stuff :thumbup:
thin gauge wire.....very dense cardboard...network cables.
That's interesting and certainly worth exploring. I'll send you some of my knives to sharpen up.![]()
As for your 440A Leek, I can't really comment on how it would perform at very acute angles. If it is soft then it will roll easily, just as some steels will chip at acute angles.
