thinning down the coating on a BK-16
So i'm in the process of reprofiling my bk16 (5 minutes here 5 minutes there whenever i get the time) and i'm thinking about thinning down the black blade coating just behind the bevel to maybe make it a better slicer. The coating is pretty thick and really rough so i thought it might improve the performance. I'm reprofiling at ~17.5 degrees so maybe i could do a couple passes at 15 degrees to smooth out the shoulders? I'm sure a lot of you have done this whether it was on purpose or not :Þ did it make much of a difference? did it affect the life of the coating a lot?
F,
I have not done anything yet to the coating on my BK16 which i the only Becker I have with the new coating.
I build some Epoxy paint coated gunstocks While the stuff provides a great grip, the paint has enough "tooth" to it that it feels unconformable along the cheek piece etc on a shooter's face. In those cases, I have used 220 and 300 grit Black carbide Sandpaper to lightly knock the "tops" off the surface to make it less grippy.
I am still wanting on some etchant/equipment to more deeply the markings on my BK-16 before I strip it's blade for good- but in the interest of science I performed a little experiment with the handle portion of BK16.
From what I have seen, 400- grit Carbide paper works about perfectly. It takes the ridges off the paint surface and makes the coating about as slick as the old Becker coating. Use a flat backer for the sandpaper and also lubricate it with some water when sanding. It should slick it right up and yet preserve it's protective qualities.
Sounds like you're convexing your blade. From what I can tell, it doesn't affect the life of the coating THAT much but it does make it a much better slicer.
I slicked the coating on my 4 (same coating as the Tweeners) and I think it improved the performance, plus it dont collect half of everything I cut anymore. I dont know how it will affect durability....but the new coating *from my understanding* is applied differently and is a different formula then the old coating, so even with the rough knocked down it should hold up quite a bit better then the old stuff does.
