I wish they used the same springs, however they're a different shape and length then the Benchmade springs. I have an old picture before it broke comparing the omega spring to the XR lock spring.I think these use omega type springs that are identical to those used by benchmade. If so, then there are people that make and sell these. One is on a popular auction site. There are generally 2 sizes. If I saw an image of the terminus xr springs, then I’d probably be able to tell if they are the small or large size. Hope that helps.
I see. I wonder if the small omega springs would still work.I wish they used the same springs, however they're a different shape and length then the Benchmade springs. I have an old picture before it broke comparing the omega spring to the XR lock spring.
What knife uses the "small" omega springs, I would think the bugout would use the smallest omega springs. Got any pictures of the springs you used?I see. I wonder if the small omega springs would still work.
Just 2 days ago, I replaced my Sog Spec Elite ii springs with replacement omega springs and they’re great so far.
The bugout does indeed use the small omega springs. If you look on the auction site or Etsy, the makers of these classify them in 2 size groups (large,small).What knife uses the "small" omega springs, I would think the bugout would use the smallest omega springs. Got any pictures of the springs you used?
I would have to cut to make the spring smaller and reshape the small omega spring for it to fit then, which I guess I could eventually give that a try if nothing else works.The bugout does indeed use the small omega springs. If you look on the auction site or Etsy, the makers of these classify them in 2 size groups (large,small).
I used large because I didn’t know better beforehand. The small ones would have fit more appropriately, but the large ones fit as well.
Well, while this may be unfounded (or it could be a genuine concern as this is something that definitely would show up) I have done work and may do work in the future that requires a security clearance, and I'm unsure if having multiple seized packages for what the CBSA calls "weapons" could be a problem or at least set off a red flag which can cause the approval process to be quite long and difficult.I posted something on this thread because i got mixed up with this one. Since, the knife is relatively not that expensive, why not risk it by sending it for warranty? Either way, if it gets seized and/or you can't find the replacement spring you're looking for, you can probably off buying a brand new since it served you well already. Unless, it has some sentimental attachment to it.
Well, while this may be unfounded I have done work and may do work in the future that requires a security clearance, and I'm unsure if having multiple seized packages for what the CBSA calls "weapons" could be a problem or at least set off a red flag which can cause the approval process to be quiet long and difficult.
That is correct and as the saying goes "once is an accident, twice is a trend...".Right, IIRC you have had a Mordax seized already...
I believe it’s stainless steel memory wire.
This does seem like the best route most likely. Probably will research some DIY Benchmade Omega spring guides and then modify them to fit the XR lock.I’ve seen spring stock for sale , that you can cut and bend at the ends to fashion your own springs. That might be the way to go.
There are several different threads here on the forum in reference to making DIY omega springs. Some people actually like their DIY springs better than the BenchMade factory ones . Good luckThis does seem like the best route most likely. Probably will research some DIY Benchmade Omega spring guides and then modify them to fit the XR lock.
