Is this a desirable/easily maintainable edge?
Is "zero-grind" easily maintainable?
That depends on how wide the bevel is and how you want to maintain your edge.
A zero-grind is more acute at the edge than if it had a secondary bevel increasing the apex edge angle. Most users/makers
strop the edge as a final step in maintenance, which puts a micro-convex bevel at the apex (can be invisible to the eye). If the edge is quite narrow and not overly hard, the steel may roll or fold out of alignment and may be stropped or steeled back into alignment to maintain cutting efficiency and durability (i.e. to keep the edge from folding over and/or tearing/chipping away). For all this level of maintenance, a zero-grind is easy to maintain and evinces superior cutting performance.
Once the edge is sufficiently damaged (apex is lost), restoring that edge
at the same angle as previously held requires removal of material along the bevel. A "zero-grind" usually entails a wider bevel, which translates to more material to remove to restore the edge at the original angle which takes more time, skill, and resources than a narrower bevel requires. In such circumstances, a zero-grind is harder to maintain. However, if the user is not concerned without maintaining the same edge angle as previously held, he/she can adjust the sharpening angle slightly wider and create a secondary bevel narrower than the primary bevel, thus reducing the amount of material that must be removed (and the time, skill, and resources required) to restore the edge, making it "easier" to maintain in the field. The new edge will be just as "sharp" at the apex, will have more material support to enhance durability (including resistance to folding),
but the wider edge-angle will reduce cutting efficiency in certain media.
In practice, one wants the most acute edge-angle possible while retaining sufficient edge-durability to not hamper performance. If your "zero-grind" knife can hold a sharp edge during your use of it without requiring frequent maintenance, :thumbup:. If not, you might consider giving it a secondary bevel...
Was that more of an answer than you were looking for?
