- Mar 5, 2009
Just wondering about members experiences with this steel and comparisons to other premium steels out there.
Does it rust easily?
How does it compare in actual use to other well respected super steels, like s30v or another tool steel like d2?
Super steel. Well balanced ( toughness& wear resistance) that loves to get and stay sharp. Use a strop for this steel. It works great and can make a big difference. Can use it from large size, high performance competition fixed blades, down to small ,thin, very sharp folders.
My kind of stuff! Joe
The rust issue is exactly why I wont buy a folder made with this steel, (or any non-stainless steel).
Pivots tend to collect water and corrosive contaminants anyway.
For a small increase in edge performance you get a large increase in wear/corrosion in the pivot area.
Fixed blades arent so bad. You can coat the steel and only have the edge exposed. I might consider an M4 fixed, but never a folder.
It doesnt make sense to me, but then, I use my knives outside a lot and they get wet and dirty. If a person never used their M4 outside I guess it wouldnt matter.
Lots of tool steels aren't stainless because rust isn't an issue. What is an issue is the cutting performance and edge retention. "Pretty" drill bits don't get points when it stops cutting before the other one. Even stainless steels will rust under wet and muddy conditions.
Yes, but not like tool steel.
True, but the tool steel will still hold a better edge then most stainless steels.
This would seem to be true, however ive found most modern stainless steels hold an edge as long as i need, and require little to no attention at a lower price point.
M4 is a great steel, sharpenes easy and gets stupid sharp. It forms a chainsaw like burr as the edge wears down and just keeps cutting.
I used my M4 mule team to cut some 3/4 manila rope, it was pretty dull after but when in use it didn't feel like it was dulling at all.
http://www.youtube.com/watch?v=sHp4E22wuSM&feature=channel_page
I would suggest you to cut it the way it does not hid wood base. Because you are not only cutting rope but as well pressing hared your edge into that wood and to my experience this damage edge way more then cutting manila rope. You may just make small cut with saw into your wood base and eliminates this problem very easy. Cut where edge will go after cutting rope.
But you will have to have much more rope in that case...
Thanks, Vassili.
