- Mar 22, 2006
Well I've been giving this topic alot tof thought Obviously location is key in this decision, and I'll hopefully be doing alot more camping than surviving so the selection should also double as a fun little campgun. That is capapble of potting small game and could concievably pack enough of a wallop to discourage the bad guys. a .22 seems almost ideal it is light and possible to carry hundreds of rounds of ammo without too much weight.. there is also a wide variety of ammo available ranging from 22 cb longs, and caps (and assorted subsonic cartridges) which are good for low noise and short range up to maxi mags and velocitors which can put a wallop on med sized game if needed. A shot gun would also be nice as a close range gamegetter witha wider margin of error (also nice if self defense is a concern.) the ability to be taken down would be a nice feature (for packability) simple rugged construction and price are also a concern as this fire arm will probably be a beater. Both rossi and H&R (NEF) manufacture matched sets a fire arm theat the barrel and chamber can be swapped out form a single shot .22 to a .410 shotgun ...I'm not sure of the rossi quality but it is avail in stainless steel with a mod. choke on the .410 (better for slugs) I have owned a H&R shotgun in the past and it was a solid piece of machinery, but the .410 barrel is full choke (potentially dangerous when considering slugs.) THe rossi is also available with a 20 gauge barrel.
Another consideration if self defens is not a concern would be a high powered pellet pistol on the cheaper side crossman makes the american classic model a .177 cal pel pistol (pump) that can generate 600 fps I've bagged several squirrels and bunnies in the garden with mine as a kid. crossman also makes a c02 powered single shot .22 pellet pistol that generate 460 fps ( i never owned this one but my friend does and together we have potted alot of squirrels at close range with it. I recently did a search on yahoo and looke up "pellet pistol 1000 fps" and came up with an awesome find (unfortubately I did not write the name of it down) but it is a 22 cal pellet pistol that you can pre charge your self that can rifle six consecutive shots at velocites up to 1000 feet per second "more than adequate for most small game at respectable ranges.
Actual handguns (something I know little about) are also a great option (for those who have access to them as they are easily stowable. I personally feel that somethin like a ruger single six with a 6 inch barrel would be a good selection The .22 model is available with cylinders that will accomodate .22 lr for small game and .22 mags for defensie purposes . this model is also available in .357 mag which will accomodate .38 specials for smaler game and shotshellls for potting things at close range...
Love to write more but the baby is crying...input as always is encouraged.
