I don't have time to get any pics. Would like to do that sometime and post them. Here's a quick overhead drawing of my shop set up. I haven't measured it but I'd guess its 8ftX14ft at the most. It fits in a 2 car garage good enough that we can still park an expedition in there while I'm working
The main workbench is right against the wall of the shop. From left to right on it I have:
First, a coote 2"X10"X72" grinder with a 1.5HP dayton motor. The motor is mounted directly to the rear of the grinder inline with it. Takes up very little space, and was easy to put together that way.
Next is a 12" delta drill press. General bits I use all the time are stored in a box on the base of it.
Next is a Delta 8" bandsaw. This little unit is far from the best tool in the world but it will cut out scale material quite well and doesn't take up much space (and its cheap
Next is a Delta 4X36" beltsander with a 6" disc on the side. This can be slid back against the wall to give me about 3 sqaure feet of bench space right next to the 6" bench vice which is mounted right on the corner of the workbench.
This workbench is actually a giant old dresser or something. Its all drawers and cabinets underneath. Gives me a place to store belts, wood, files, and all that kind of stuff. Right at hand, you don't have to walk anywhere.
The second bench/table on the end is my welding table. I slapped this together with some angle iron. The top is inlaid with soft fire bricks, and has fixtures on the 2 corners for my bench grinders.
One of the bench grinders runs at 3450 rpm with 36 and 60 grit wheels and is used for rough work, profiling, cleaning scale off etc. The other grinder on the back corner (farther to the right in the picture) runs at 1725 rpm with 60 and 120 grit wheels. I use it to sharpen drill bits and other tools.
Underneath the welding table is a shelf. It has a 4 drawer tool chest on it that I keep small hardware, handtools, files,patterns etc. in. Also keep tongs and hammers in the top tray of it. Beside the toolbox, I have my quenching oil, containers, some scrap steel and all other miscelaneous stuff.
Out in the middle area I have my forge and anvil.
This is a little bit more cramped than I would like, but it is kind of nice in the end. I'm never more than a step or two from anything I might want.
I should add that the welding table is on casters so I can roll it out into the middle of the garage if I want to do larger welding projects or anything away from the knifemaking tools.
And I have another table and small tool box in the basement of the house where I do final fit up and glue work. I could easily do without this table, but its nice to have.
Things you should really think about in your shop are cabinets/drawers for storage, and lighting. If you have an easy way of putting stuff away you won't clutter the benchtop up leaving things out. And good lighting is a must.
Hope that helps
