are they hard to clean? I always wondered why they didn't use a closed bearing system so you don't loose the bearings
Yup, me too.The smoothest IKBS knives I own are Todd Begg. Those things are so smoooooth.![]()
They are usually packed in grease so if you do take it apart you shouldn't lose bearings. If any do fall out they are quite easy to put back in. I always have my IKBS knives in a plastic bag when I break them down. As far as cleaning goes, I blast the pivot with WD-40, then canned or compressed air, and then lube lightly using Tuf Glide. A closed bearing system wouldn't give you the same surface area and wouldn't allow for that same super smooth and fast opening.
There really shouldn't be any need to break your knife down. I find that if I clean the pivot once a month I have no need to disassemble.
But aside of smoothness, does it offer other advantages over washers?
Will the knife be tighter, less blade play? Will IKBS allow to transfer bigger lateral forces without damage?
