Thoughts on Skeletool vs Juice S2
Hey everyone, I've been thinking about getting either the Leatherman Skeletool or the Juice S2. I just wanted to share some of my thoughts and see what you think. There are some questions at the end I'd like answered. Please and thanks!
The most obvious differences between the two are as follow:
  • Scissors
  • Can Opener
  • Bit driver. I personally think ALL pocket sized (measurement according to Leatherman's site) and up multi-tools should include this. They make such a great bit kit yet so few models can use it!
  • Carabiner attachment
  • Pocket clip. Tip down :( . It seems like it was designed that way so I can't switch it.
Less obvious differences:
  • One hand opening blade that could function fairly well as an EDC. Would prefer the grind to be higher up and the tip to come to a more abrupt point like the Charge/Wave series
  • Slightly larger needlenose pliers (than the Juice S2).
  • 1 inch longer. Not a big factor for me
My thoughts:
Couldn't the lack of tools on the Skeletool be overcome with keychain tools such as the ones pictured below? Before anyone else thinks this, here are my thoughts regarding "add another multi-tool to your keychain!". A S2, Micra, Style CS, etc would be nice but would cause too much redundancy (and keychain weight!) for my tastes.
Total weight:
Because the Skeletool has a fairly competent blade, I think it would serve the EDC purposes. Some of my weights might not be accurate. Couldn't find them anywhere on the web!
Skeletool (5.0) + Slip-N-Snip Scissors (1.0?) + P-51 (.5?) = 6.5 oz total
Fairly troublesome to assemble all the supplementary tools but I think it'd be worth it for the bit driver alone. I don't plan on putting a P-51 on my keychain but this was just to compare apples-to-apples in terms of tools.
Leatherman Juice S2
  • Scissors. Yes, the Juice has them but I've read that they're not that great to use. I've never used them but I still think that Victorinox scissors are the best.
  • Can Opener. I personally think this is a waste of space since one could just use the P-51 or P-38. Give me a file or saw!
  • Bits. 3 flatheads!!!???? Give me a break. I'll take the bit driver anyday
  • NO Pocket clip. Not really a concern for me. If it is for you, get a Nite-Ize eCLIPse. It was designed for cell phones but should work on any flat surface.
opplanet-nite-ize-black-stainless-eclipse-selflocking-clip-for-cell-phones-ecls-03-01-01.jpg
  • The blade is rubbish. Only serviceable as a backup blade in my opinion.
  • Slightly smaller needlenose pliers (than the Skeletool). Better for precision work?
My thoughts:
While the Juice S2 is a better package in itself, I think the bit driver alone in the Skeletool is worth the trouble it'd cause to make the combo I described. The benefits regarding this combo is that while it's slightly heavier (I don't have any 1.8 oz EDC knives, especially not one that can at least match the Skeletool's in size), one can get a much better choice of EDC blade. For example, what if you want a tip up blade? What if you need a workhorse EDC that has plenty of jimping and aggressive G-10? The Skeletool is really a one-size-fits-all blade. Not really as versatile as the Juice combo.
Weight:
Juice S2 (4.4) + Nite-Ize eCLIPse (.3 according to my scale) + EDC Knife (1.8 or less) = 6.5
The reason I say the EDC knife should be 1.8 oz or less is so that it can match the weight of the Skeletool combo. You don't really need the Nite-Ize eCLIPse. Just trying my best to match apples-to-apples
My questions to everyone:
  • Are the pliers on the Skeletool stronger than the S2? If so, why do you think so? My guess is that the difference is negligible. For me, I think I'd like the S2's pliers for more precision-oriented work.
  • How well do the Slip-N-Snip scissors compare to the Leatherman Juice S2 in terms of size? Would the scissors on the Juice S2 be able to cut through zip ties with relative ease?
  • Which tool is thicker? From my research they're about the same thickness but I'd like it if someone could post a photo comparison.
  • Is my thinking flawed in some way? Did I forget some details? Post below if you think so!
