I’m FINALLY making more progress on my surface grinder attachment for my KMG. I’m to the point that I need to mount my 3” serrated contact wheel to the 1.5” tool arm and then I can figure out the best placement and angle for the rail, etc. I’m finding myself at a mental block for how I want to attach the contact wheel.
Originally, I planned on some all-thread and was going to tap the hole in my tool arm. But, the 1/2” rod has just a bit of play when slid through the bearings on the wheel. Which made me think I’d get some 1/2” cold rolled steel, thinking it would be a better fit inside the bearings. But, should I thread part of the rod and tap the tool arm? Should I leave the rod smooth and just thread the ends? Would only have to worry about drilling a perpendicular hole and not about threading it perpendicular as well.
I feel like this isn’t as hard as I’m making it, I just don’t want to mess up the tool arm or end up with an out of square hole.... I have a G0704 I plan on using, but also trying to figure out if I should use drill bits and get a reamer or if a 1/2” end mill will leave me a round hole. As you can tell, I’m not a great machinist...
. Thanks for any help and/or suggestions you have.
Jeremy
Jeremy
