- Nov 24, 2005
Hello Everyone,
I didn't want my first post to be about something like this, but that's what I get for reading and not typing, I guess.
I ground out my own version of a Puma Seahunter in 1.5"x 3/16" 154CM. That went well enough. I threaded the tang for 12x24, slotted a guard out of 304 stainless, made a butt cap from the same stuff and made a take down nut out of stainless rod from the hardware store to hold the whole thing together. I'm using a block of black linen micarta for the handle-block was drilled out for the tang. I got all that done and sent the blade off for heat treating- double drawn and cryo treated.
I got the blade back a few days ago and put the thing together, fitting the guard better, etc... I must have torqued it together too hard because after about 6 screw togethers, I left it assembled and walked away. A few minutes later, I heard a sound like glass breaking and the knife came apart. The tang snapped at the last thread on the shoulder of the tang, taking about an inch and a half of tang away. I assumed that at least the threaded section of the tang would be softened by the heat treater in anticipation of being assembled. I guess I should have softened it myself. I'm just glad that this happened before I gave the knife to the person I'm making it for. Did I mention that I just picked out the most appropriate seeming size die from my tap/die set for 3/16" diameter and managed to pick an obsolete automotive thread? Things always seem to work out better when I'm making the knife for myself...
I'm thinking that I should nickel silver braze a 1/4x20 or 1/4x28 bolt (no one has 12X24) onto the tang and drillout/thread another take down nut...of course I'll have heat stop paste, wet rags, etc. to keep the blade cool during the brazing. I did try to thread further up the tang without any luck. Keeping in mind that the knife has to be readily disassembled, are there any other options for threading or any pointers for the type of steel I'm brazing?
Happy New Year, by the way!
Thanks,
Tony
Thanks,
Tony
