- Oct 30, 2002
After going through the trouble and expense of setting up my VFD in a clean box and running the remote controls for it for my KMG, I just didn't want the headache or bill from doing the same thing two more times. However, after adding a disc grinder set up on a 3/4 hp 3phase motor and another 2x72" grinder with a 2 hp 3phase motor, I needed an option to control the extra grinders.
I had the idea of using change over (rotary cam) switches. These types of switches are designed for use when changing over 3phase power from shore to a generator on big boats, but the switches are pricey. Pretty much all of the rotary cam selector switches that can handle the load were just too pricey to pull the trigger. So instead, I opted for plain on toggle switches. After some searching, I found these 3 pole, 2 position, screw post toggles rated at 30 Amps @ 250V. I ordered two of them and set up the switch box tonight.
It has the capcity to add another switch if I add a horizontal grinder in the future.
The input comes in from the VFD via 14/4 stranded wire and on to the first switch. When the switch is in one position, power goes to my 2hp KMG. When it is switched to the second position, power is sent to then input on the second switch. The second switch can be thrown to either control the disc grinder or my EERF 2x72" grinder. All the grounds are tied in to each other seperate of the switches.
My VFD is 2hp, and you can control anything at or under 2hp with it. I use the same remote controls and VFD to control all three of my grinders!
Just thought I'd share. Thanks for looking!
--nathan
--nathan
