Throwing Busses?!
Zal
A conversation we had in #Busse (on IRC--you should try it!) last night inspired me to take it upon myself, in honor of my *not* being chosen for the test team, to test what knives I have and post my own brand of data under my usual forum name.
I was curious as to what percentage of "sticks" (Knife buries itself blade-first into the target and doesn't fall out) I could achieve with the Busse / Swamp Rat blades I had handy. Handy turned out to mean my Air Rescue Knife and my Rat Shaker.
First of all, let me say this--these knives aren't throwers. Maybe it seems obvious, but something a bit bigger (but not too much bigger! I could only stick my Himilayan Imports 18" Ang Khola three times--but that was just me being goofy) with more heft to it would definately be more suited toward the task.
Nonetheless, I'm a hard-headed rascal, so off I went to the target I've got set up out behind the garage. It was lightly sprinkling rain, just enough to make everything a little wet and make nice little gummy specks of wet dirt for my missed throws to fall into. Handles were slick by the end of the "experiment" so grip probably factored in as well.
My particular throwing technique is probably what you could consider traditional. Find one's distance, throw the knife so that it rotates once and then sinks into the target point first.
I'd been curious as to how well the Rat Shaker would throw for quite some time, so it was the first knife I used. I didn't expect good results, so I was rather pleasantly surprised when my second attempt netted me a stick. Beautiful stick. The knife just buried itself into the target and made me wish I had brought my digital camera, rain or no. I counted from the first stick, considering it to be the point where I had found the proper distance to throw from, and threw the shaker 50 times. 25 of those times, it stuck, with "streaks" of hits up to 4 in a row. 50% accuracy with such a little, light knife.
Next, out came the Air Rescue. I had thrown this knife before, so I was hoping for at least around 60%, particularly considering the advantages it has over the smaller Rat Shaker--namely more weight and a better point, not to mention the fact that I had thrown it before. It took me longer to find my distance with the ARK, and once I did, I was surprised. Throwing the ARK tended to be more streaky than the Rat Shaker, with as many as six sticks in a row and similar numbers of misses in a row. All in all, I stuck it 23 of 50 throws--46%.
The larger Air Rescue was out performed by a little rat. I must say that the dampness affected the ARK's grip more than it did the rat shaker, partially because of the holes in the Rat's handle which allowed me more purchase, so maybe I'll do a "dry" run later when the weather is better.
:D
Cool! I can throw a hatchet, but last time I tried to throw a knife it bounced back and had me on the run. :o I must have done something wrong:rolleyes: :D
. . . nah. It's just one of those hazards of knife throwing. ;)
So thats why all you bastids are not at work this morning! You all sat up 'chatting' all night!
Well, there are only 3 in here today, so get ya slack ass' out a bed and start talkin' INFI...:D
Gundy, you should join us tonight. It usually starts hopping around 03:00 GMT. ;)
You could see the "We need an AIM Chat for all us Busse nuts" thread for more info, but I'll repost mschwoeb's easy-to-follow directions here.
Originally posted by mschwoeb
Lets make this 2nd grader level instructions.:p
1. Click on the link
http://mirc.com/get.html
2. Install the program
3. click on the link on the desktop that you installed to run the program.
4. Click on the little icon that looks like a folder with a hammer next to it.
5. should see connect, then select the Tell mIRC to connect to a random NEWNet server, and put in your desired nickname
6. select the folder with the #+ in it.
7. click on the add button, then where it says channel type in #Busse
8. select join on connect.
9. click join.
10. celebrate with the guys that you made it.
*If this above information does not help, then please feel free to contact your frienly tech support guy, right here in Indiana. Cost is only $100 shop credit for every 10 minutes of phone time.:)
Ha! You dearer tha me! But hangon, you are using USD...;)
I am there! See you guys this arvo...
Zal,
How do you construct your target/backstop? Getting ready to build a new archery backstop & might set up something for throwing as well.
Later,
Bill
Well, it's a real scientific process with us.
We took a really big hunk of tree that my cousin had cut down, and used a tractor to put it in the forked stump of said tree we cut down.
. . . I don't recommend it. Not a very good target. I need to figgure out how to build a decent one myself--sorry I couldn't be of more assistance!
Zal,
I am trying to decide between the butt of a saw log and sawn lumber- & if lumber, end or edge for sticking. If I get it doen, I will post pics and opinions.
Alpha,
If ya wanna throw sharp things, you HAVE to have fast reflexes... :)
Later,
Bill
I am using a cross section of log about 24 inches in diameter and 6 inches thick. I recommend going into the end of the grain, if you go sideways into the grain it's harder to stick knives that aren't lined up with the grain when they hit. But then I am using Rigid throwing knives, and they aren't exactly sharp, mostly just pointy.
Originally posted by edhall
I volunteer, you can throw them at soft me, if they stick I get to keep them.
Reminds me of a free MOAB plan we had discussed at Blade. :)
I tried throwing a Busse one time.
But all I threw was my back and boy was Jerry pissed when he had to pick himself up and dust himself off. Almost cost me my INFI allowance.:eek: :D
Hey Zal
Depending on how heavy the knife is a better method for trowing you knife might be the under hand slip method you put the knife flat in the palm of your hand with the thumb across the handle point forward!
Let knife slide out of your hand with no flip! the knife has to be fairly heavy for this to be affective! but i find it to be easier to control.
Robert
So many knives so little money
I've only tried that once or twice.
Next time I throw some, I'll have to play with it--I'm just kind of used to the one rotation method.
