I don't know where you're going to find heat treated 1075. Most steel is either annealed, or left in whatever work hardened condition it ended up from manufacturing. There are some steels that come pre-heat treated but they are generally soft stuff that can be machined easily afterwards (this is done to prevent any warping from heat treat after machining to final dimensions).
Anyhow.....getting the stuff already hardened would make your job difficult, because the stuff can't be cut with normal tools. Drilling would require carbide, and cutting would require something other than a hacksaw or bandsaw. Files won't do too much either.
Heat treating it really isn't that difficult for wht you want to do, providing you have something to heat it with. It would just be a simple full quench and then throwing the thing in the oven for a few hours to temper. Really is the best way to go.
