My Ti Salsa came today and since I had not seen any of the Salsa's before I was favorably impressed (like the new box too
The quality and fit 'n finish is maybe not as good as the best Spydies ever but still seems excellent. The blade grind on mine is a bit rough (vertical lines) but even and typically Spyderco sharp. My blade is a bit off center when closed (first time that's ever happened with a Spydie) and while the lock up is good it's not as good as the Compression Lock was on my Gunting. I actually expected it to lock up tighter being 'almost' a frame lock (I have Reeve, Mayo, Ralph framelocks and they have always been the most solid folders to me).
My question is; there seems to be a definate stop or hitch in the closing process? If you are gently closing the blade it 'stops' at about 80% closed and has to be pushed through a detent to close all the way. Is this the blade catching on the 'detent' for the mono-lock? Is this normal or should I consider sending it home to be looked at?
A suggestion too
This is a knife that begs for Boron Carbide! I've heard Sal has a BC coated Millie and I have the parts for my large plain Sebbie off at Bodycote right now
I'd be sooooooo tempted to send the frame/slabs and maybe the Cobra Hood off for coating! Now that would be sweet (and probably more durable too)!
A suggestion too
