From a medical standpoint, just get the tick off your body. Fingers, tweezers, whatever. And don't worry so much about technique - it doesn't really matter if you leave a bit of the "head" in place or "compress" the body. There is solid medical support for the idea that getting the tick off the skin within 24 hours is the most important factor in preventing tick-borne illnesses.
asfried2, I see you say you are a Pediatrician. I have read that there is very little evidence that a tick can transfer any disease in less than 24 hours but does that include if you are abusing it by squeezing the body instead of removing it properly? Is it because it cant break the skin barrier in less than 24 hours so no matter what it spills into you it wont get inside the body? I'm asking you because "youre the doc".
Thanks,
KR
Thanks for asking KR1,
Interestingly, I just got back from the Wilderness Medical Society conference a couple of weeks ago where this issue was discussed in depth. Here is the recommended tick removal method per the wilderness medical community:
From "Wilderness Medicine" by Paul Auerbach (the standard text for Wilderness Medicine health professionals):
"A quality pair of fine-tipped forceps is necessary to safely remove embedded nymphal and adult ticks, by gently grasping the tick as close to the skin as possible and gradually retracting outward in a straight line. Special tick-removal devices available from outdoor and camping supply companies provide some advantage over simple forceps but generally cost more. The area should then be cleaned with a local antiseptic. Other methods for tick removal, such as applying petroleum jelly to the tick, or using a lighted match or cigarette, isopropyl alcohol, or fingernail polish, do not ease removal of the tick. These and other "remedies" most likely increase expression of tick saliva and foregut contents, thus increasing the chance of disease transmission."
WOW, you guys sure do get technical over ticks. I do everything I can to prevent them but if I get one I just pull it off, same with a leech. I never put any thought into the proper way. Chris
