Tiger Claw "KyPly" sheath for the ASH1-LE
Everyone is posting their sheath pics, so I thought I'd post a couple for my new ASH1-LE
Of course, it has adjustable tension. This allows the user to set the desired amount of retention. Also, it features removable hardware, allowing the user to thoroughly clean out the interior of the sheath.
Dang. Thats a fantastic design.
wow!
what a great idea!
(the adjustable retention)
very impressive.
:D
I agree that adjustable tension is a good idea. I pioneered it way back in 1996 for a guy that wanted to carry a tanto-style blade inverted behind his hip. The handle had nothing to engage, so I came up with adjustable tension for knife sheaths! (the guy still uses it, too!)
The "KyPly" is original with me, too. It's a PIA, but it does make a pretty snazzy sheath or holster.
Nice looking sheath, reminds me of Wolverine or something. Now maybe it is just me but don't the hex head bolts present a greater surface area to snag on something rather than standard eyelets? Seems to me if you just made a big enough drain hole you wouldn't need to be able to separate the kydex. What keeps them from loosening in the field? Blue Loctite maybe? How easy is that to break free with minimal tools, which also stand the chance of getting lost while afield?
I agree that the adjustable tension is a nice option, especially if you are making several sheaths for knives not in hand and the handle tolerances are varying. It is just too bad you couldn't patent it way back in 1996. Of course it would be hard to prove that it had never been done before. It would be like someone who makes leather sheaths trying to lay claim to making an adjustable retention strap.
What was it one guy said in an earlier post? Oh yeah, "nothing new under the sun".
I also use "button head" screws, if you think that these will catch on things. I've never had a problem, myself. These other screws are evident in another picture I posted showing a SJTac
Ever have to sheath your knife when it was bloody or muddy? The whole idea of making it so you could remove the hardware was brought about by a friend that had trouble sheathing his knife kydex, because it had accumulated a bunch of debris along the way. You can only clean out so much from the opening and/or drain hole.
There are star washers under the screwposts, allowing you to crank down on the fastener without needing loctite. I've considered affixing the allen wrench to the sheath itself to assist in takedown, but it occurred to me that you'd hardly ever need to do it afield. This is because it typically takes some time to accumulate enough debris for it to be a problem. I've also used thumb screws, making the design entirely tool-less, but I thought those would be a snag magnet. Yes, you could lose the screws, screwposts, allen wrench, sheath, knife and even your way. There are no guarantees in life !
Patents are expensive (I checked) and easily thwarted. (He uses "x" whilst I use "y", so it's 'different'.......")
I was just relating the first time _I_ used/developed an adjustable tension sheath.
